Hello, I’m having trouble creating any kind of motion blur within a Bongo3D+Vray animation, Vray chaos group have very little if any info in their Vray for Rhino manual and no simple examples or tutorials to follow for beginners.
Using IK creates multiple object trajectory’s within my model, this makes faking motion blur in Photoshop annoyingly complicated and inaccurate.
So what I am trying to do is create a small animation and then extract stills from this to print (student project pin up).
It would be most helpful if someone could tell me if this process (work flow) is actually possible?
Thank you Menno,
Yes my spelling is that bad, I could do with more of these cartoons keep’t in my wallet, can you tell me where you got it from please?
Vern,
Date: Sun, 3 Nov 2013 09:03:41 +0000
To: verniture@hotmail.com
Subject: [McNeel Forum] new post in ‘How to?, MOTION BLUR with Bongo 3D & Vray to express motion in still architectural renders’
menno
November 3
To respond, reply to this email or visit http://discourse.mcneel.com/t/how-to-motion-blur-with-bongo-3d-vray-to-express-motion-in-still-architectural-renders/3549/2 in your browser.
I decided to remove it because I saw you are new here and I wouldn’t want to come across as being a total dick. Of course, you already got a message with it, so there goes my plan. Anyway, I’m glad you appreciate the humor
The cartoon was from The Oatmeal, this one http://theoatmeal.com/comics/misspelling
The answer is that VRay has to support motion blur - I’m not sure that it does. The only renderer I know of that does support M-blur is Brazil.
However…there is a post effect trick. If you render twice as many frames as you need, you could use something like After Effects to add the motion blur by interpolating between frames.
Thanks for the reply, Vray dose support Motion blur so I’ll ask the question on a Vray forum as well, although I think you and this video tutorial (http://vimeo.com/9440705) show that it is faster to do in after affects as a post production technique.
I’ve also just come up with a cheat, fast, low rez way of doing it, ( play the animation in VLC mediaplayer with motion blur on, Then as it seems to be imposable to export from VLC with the motion blur filter embedded I will Screen capture or screen film with DVDVideoSoft Free Studio and then multiply the image on to my still render in Photoshop.
I thought it was best to ask the question here on this forum first as it’s primarily animation, Thank you all for your input.
I’ll post some images when im done,
Kind regards
Vern Roberts
