How can I clean/optimize faces (meshes)
FR56_reduced.rar (4.2 MB)
Hello all,
Here I’m adding an image and rhino 6 file to ask your help. My problem is the meshed faces which are broken into pieces. I want to recreate them as single clean surfaces. Any command or method to do it properly to save me time? I need merged clean surfaces.
First, Try converting the Mesh to Nurbs. And then join the surfaces together as polysurface, run the Merge all coplanar faces command. This might help you create a polysurface with least complicated polysurface possible.
