How can I blend these surfaces smoothly
I can’t figure out how to blend these surfaces smoothly. Any idea?
Not trying to be rude, but you need to be a bit more specific! Which surfaces? There’s a lot of surfaces in that screen sho. An indication of from and to where the blend should go and also the type of surface (straight, tangent, kinks/no kinks etc.) would be nice. Also, it’s better to supply a file with the relevant surfaces in it - that way people have a chance of actually showing you, instead of writing loooong explanations that might not be understood.
-Jakob
sorry about thathelp_with_blend.3dm (9.0 MB)
The quick and dirty solution - as long as there are no specific cross sections to follow - would probably be patch.
HTH, Jakob
help_with_blend_JN.3dm (4.1 MB)
Thanks for the help! You created two additional lines as I did in the picture and then did patch?
