Hello guys,
As for the vertices in a loop, how can I align them easily in on plan (like the function in T-spline)? Now I can just move them one by one using xyz.
And also, how can I move single vertices align the SubD edge (as the red arrows show)?
Thank you so much!
Hi @w.wu
Use the Align command > ToFitPlane option.
Regarding your second question, I’d just delete the edgeloop so you don’t stack verts and cause other issues.
use gumball-
select all points, scale to 0 using the appropriate scale handle-
move them as needed with arrows-
bonus party trick, rotate the gumball 1st to pick which plane you want to align to then scale to 0-
(rescale as needed if the points are squidged in a way you don’t want them)
Thank you for your reply.
For the second question, I am sorry I was not clear. I mean, if I choose a single vertex, and want to move it along the edge it belongs to, how should I do it?
Thanks again!
Thank you so much, @theoutside!
Your method is so powerful and easy to handle!
use the “slide” command
That command is fantastic!!
Thank you again, @theoutside!
Have a nice day
