Hi community,
I would like to apply hatch on each cell and not on all the cells as a whole. I could do this one cell at a time but it can take ages. Is there a way to apply the radial hatch through grasshopper on each cell?
Thanks
Hi community,
Thanks
graft your inputs
Hi, can you say more. I did this on Rhino. No sure how to graft
right click on the output of battery that passes the geometry to the shader, and select graft
alternatively, graft the input of the shading battery (same method)
It still created one giant gradiant but not a gradient for every cell- I connected the point cloud to base point in ´Model hatch´
provide the *.gh file with internalized data
temp.gh (15.6 KB)
How do you know what to graft/flatten. Its so many inputs and outputs
Thank you! Is there any way to control the gradient more accurately and not just giving black and white as input
Late reply but is there any may to have the gradient not radial/circle but in the shape of the closed curve in which it is applied.
You can use either Linear or Radial gradients.
