The same geometry works fine for a Floor made using AddFloor so I’m currently replacing the native floors (not the best thing to do, I guess…), is there a way to avoid it?
Massimiliano, Can you post your Curve and what version of Revit & RiR you are working in? This info can be found in the More>About tab in the RiR Ribbon.
I’m not getting an error even though the Graphical element was created via UI and has a Span Direction.
I didn’t get any solutions yet by my side. I’ve noticed that the compenent should run correctly if the floors are made using RIR. I guess that it depends really on how revit is structured within its API.
Turn around>>>I’d suggest to re-make the floors using the AddFloor component (hope that they don’t contains too many infos/parameters to rebuild), and then run the modify Host Profile component.
Thanks.
All walls and columns have their top and bottom attached to the floors. Re-making the floors with Add Floor will lose all those.
I’m wondering if we can reassign span direction to those floors.
