Hey there,
by starting with Hops I realized that a simple tree will lead to mismatches in the file calling the function. Is this sth which will be solved in further releases? Or will hops not be the tool for tree operations since “…Hops will spawn a new parallel thread for each branch of a tree”?
The RH_IN and RH_OUT syntax still works. I’m trying to get this to the point where you can just use all of the “Get” components as inputs and have things like the “context bake” component for output, but I’m not there yet. This way you would be able to use the same definition for both hops and the grasshopper player.
Had to be something else, but the only change I made was unhiding the console window.
Just to be sure, I hid the console window again and restarted Rhino: everything is working well.
