"HOPs failed to deserialize itself"
Dear all,
I encountered some issues with HOPs that it ‘failed to deserialize itself’ - and the HOPs component is removed from the Grasshopper canvas.
Has anyone encountered this and found any solution to it? Below I attached the error message from GH as well as the system and version info.
Rhino version: 8.24; GH version: 1.0.0008; HOPs version: 0.16.27
Error message from Grasshopper
info: Plugin version: 1.0.0008
error: Object ‘Hops’ {c69bb52c-88ba-4640-b69f-188d111029e8} failed to deserialize itself: One or more errors occurred. (A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. (bsl-br01-2492:5000))
info: Object list read
System info and Rhino version
Rhino 8 SR24 2025-10-8 (Rhino 8, 8.24.25281.15001, Git hash:master @ ba28668a8431990c700173e46ef2dbcb873cf092)
License type: Commercial, build 2025-10-08
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 128GB)
.NET 8.0.21
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 5070 (NVidia) Memory: 12GB, Driver date: 6-24-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 576.88
Accelerated graphics device with 4 adapter port(s)
  • Secondary monitor attached to adapter port 0
  • Windows Main Display attached to adapter port 1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-24-2025
Driver Version: 32.0.15.7688
Z-Buffer depth: 24 bits
Total Video Memory: 12227 MB
C:\ProgramData\Beam\App\netcore\Rhino\RHINOBEAM.dll “MKS BEAM” 1.12.0.4
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.39.7\net8.0-windows\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.39.7.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.65.21\net8.0-windows\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.65.21.0
c:\Program Files\Solemma\ClimateStudioRhino\Plugin\ClimateStudio.Rhino8.rhp “ClimateStudioRhino8” 2.2.9338.29724
Hi. Sorry for the trouble. Are you able to upload the Grasshopper definition that you’re trying to load which throws this error? It would be best if you could also include the base Grasshopper definition (i.e. the one that is being referenced from the Hops component) as well. Does this happen on all of your Hops definitions? Or just this one?
