Hi
I created the grasshopper script as per the short video by Andy Payne. When I try to load the script through Hop, I get the following error message
- Path appears valid, but to something that is not Hops related
Regards
William
Hi
Regards
William
Hi William -
Please run the Rhino SystemInfo
command and copy-paste the result here.
Rhino 7 SR7 2021-6-9 (Rhino 7, 7.7.21160.05001, Git hash:master @ d2161989109d5dacba531310b5d345ce6f4da9f6)
License type: Commercial, build 2021-06-09
License details: Cloud Zoo
Windows 10.0.22000 SR0.0 or greater (Physical RAM: 5.9Gb)
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon™ Graphics (AMD) Memory: 2GB, Driver date: 10-5-2021 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context 21.30.26 30.0.13026.3
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 10-5-2021
Driver Version: 30.0.13026.3
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Scan&Solve Pro for Rhino 6 & 7\SnSPro_Rhino_6+7.rhp “Scan&Solve Pro for Rhino” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.7.21160.5001
C:\Users\44798\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
Hi William -
Yikes. Please update to the current Rhino 7 SR18.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Unfortunately Having updated to the latest release, it still does not work.
Regards
William
Hi - your new information still says SR7.
Where do you get SR18 from? Then I ask about updating in the help file it keeps on saying that my version is up to date.
Hi William -
In Rhino, run Options
and go to the Updates and Statistics
page. Make sure that Enable Updates and Usage Statistics
is turned on and set the Update frequency
to Service Release.
Ignore my last email. I now have SR18 as per the screenshot but I am still getting error message from Hop.
Thanks William!
I recreated that gh file from your screenshot and that worked fine here. Can you post the actual file that you are working with to see if that makes a difference?
Thanks,
That one works fine here as well.
Which version of Hops are you running?
