Hi, we’re trying to work with a couple of .shp files (100mb, a process without hops around 2 min) inside a ‘hops’ component. We are getting this error.
Any idea how to solve it?
Thank you!
CG 6002 [22:29:15 ERR] An exception occured while processing request
System.ArgumentOutOfRangeException: capacity was less than the current size.
Parameter name: requiredLength
at System.Text.StringBuilder.ExpandByABlock(Int32 minBlockCharCount)
at System.Text.StringBuilder.Append(Char* value, Int32 valueCount)
at System.Text.StringBuilder.Append(Char[] value, Int32 startIndex, Int32 charCount)
at Newtonsoft.Json.Utilities.JavaScriptUtils.WriteEscapedJavaScriptString(TextWriter writer, String s, Char delimiter, Boolean appendDelimiters, Boolean[] charEscapeFlags, StringEscapeHandling stringEscapeHandling, IArrayPool`1 bufferPool, Char[]& writeBuffer)
at Newtonsoft.Json.JsonTextWriter.WriteEscapedString(String value, Boolean quote)
at Newtonsoft.Json.JsonWriter.WriteValue(JsonWriter writer, PrimitiveTypeCode typeCode, Object value)
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeObject(JsonWriter writer, Object value, JsonObjectContract contract, JsonProperty member, JsonContainerContract collectionContract, JsonProperty containerProperty)
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeList(JsonWriter writer, IEnumerable values, JsonArrayContract contract, JsonProperty member, JsonContainerContract collectionContract, JsonProperty containerProperty)
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeDictionary(JsonWriter writer, IDictionary values, JsonDictionaryContract contract, JsonProperty member, JsonContainerContract collectionContract, JsonProperty containerProperty)
at Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.Serialize(JsonWriter jsonWriter, Object value, Type objectType)
at Newtonsoft.Json.JsonSerializer.SerializeInternal(JsonWriter jsonWriter, Object value, Type objectType)
at Newtonsoft.Json.JsonConvert.SerializeObjectInternal(Object value, Type type, JsonSerializer jsonSerializer)
at compute.geometry.ResthopperEndpointsModule.GrasshopperSolveHelper(Schema input, String body, Stopwatch stopwatch) in C:\dev\github\mcneel\compute.rhino3d\src\compute.geometry\ResthopperEndpoints.cs:line 116
at compute.geometry.ResthopperEndpointsModule.Grasshopper(NancyContext ctx) in C:\dev\github\mcneel\compute.rhino3d\src\compute.geometry\ResthopperEndpoints.cs:line 172
at System.Dynamic.UpdateDelegates.UpdateAndExecute2[T0,T1,TRet](CallSite site, T0 arg0, T1 arg1)
at Nancy.Routing.Route.<>c__DisplayClass4.<Wrap>b__3(Object parameters, CancellationToken context)
CG 6002 [22:29:15 INF] ::1 - [2022-11-23T22:29:15.2381198+01:00] "POST /grasshopper HTTP/1.1" 500 -
