Hi - I’m getting an error from hops “unable to convert resthopper data” while trying to use a large definition which has some C# and python components. I’m getting a partial response (2 of the 3 geometry outputs returning curves)
Details:
it works as a definition and as a cluster.
running hops 0.16.0
2 ouputs that are coming into grasshopper: RH_OUT:TWEEN LINES, RH_OUT:ORIGIN CURVES
the output that isn’t : RH_OUT:IMAGELINES (but it still shows geomtry in the json just not coming into grasshopper)
my response json doesn’t show any errors and looks to return solveResponse.json (9.0 MB)
I can’t post full script, but can send partial if helpful.
UPDATE:
process of elimination, started working backwards moving things outside the scriptand found that something about this highlighted group seems to be culprete of the error - at least if i return the rectangles, if i output the driving values and move this construction of rectangles outside the hops definition everything works correctly.
