Holomark2_R6 stops prematurely in V7. Runs properly in V6 and V8
When run in V7 on my desktop Holomark2_R6 stops prematurely, and not always after the same step. Frequently it stops after
GPU_06 Test took :0.5 sec @ 200.0 fps.
Most recently it stopped after
GPU_13 Test took :0.05 sec @ 2000.0 fps.(Command line history from this is below.)
Holomark2_R6 in V7 may have completed once but I did not save the results.
Holomark2_R6 completes when used in V6 and V8.
Rhino 7 SR21 2022-7-25 (Rhino 7, 7.21.22206.19001, Git hash:master @ 3f1dd59991765124a9a1624615db342667a7648e)
License type: Commercial, build 2022-07-25
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 5-19-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.96
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-19-2022
Driver Version: 30.0.15.1296
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\Holomark2_R6.rhp “Holomark2_R6” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.21.22206.19001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.21.22206.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.21.22206.19001
C:\Program Files\Rhino 7\Plug-ins\MeshCommands.rhp “MeshCommands” 7.21.22206.19001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.21.22206.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.21.22206.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.21.22206.19001
Command: HoloMark2_R6
Preparing Holomark 2 R6 v2,61
Rhino 7 sr 21 64 bit
Starting Holomark2
Rhino’s language is English
1, C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HoloMark2_Mini_black.3dm
HoloMark2_Mini_black.3dm was located
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_Wire.ini
HM2_V6_Wire.ini was located
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_Shaded.ini
HM2_V6_Shaded.ini was located
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_Render.ini
HM2_V6_Render.ini was located
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_Illustration.ini
HM2_V6_Illustration.ini was located
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_RenderSpeed.ini
HM2_V6_RenderSpeed.ini was located
All is ok
Time to regen viewport 10 times = 0.00 seconds. (0.00 FPS)
HM2_V6_Wire is installed!
HM2_V6_Shaded is installed!
HM2_V6_Render is installed!
HM2_V6_Illustration is installed!
HM2_V6_RenderSpeed is installed!
Creating meshes… Press Esc to cancel
GPU_01 Cube 4 tests took :12.5 sec @ 1250.0 fps.
Calculating Contours
Contour: 2.51446 s
CPU_01 Booleans and Contours took :3.81 sec
CPU_02 UDT Shape took :0.96 sec
GPU_02 Test took :0.98 sec @ 102.0 fps.
Time to regen viewport 10 times = 0.02 seconds. (625.00 FPS)
-_Import
“C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HoloMark2_Mini_black.3dm”
_Enter
Successfully read file “C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HoloMark2_Mini_black.3dm”
_Enter
Can not close the last viewport
CPU_03 Meshing Rhino took :2.42 sec
GPU_03 Test took :0.05 sec @ 2000.0 fps.
GPU_04 Test took :0.08 sec @ 1250.0 fps.
GPU_05 Test took :0.39 sec @ 256.4 fps.
Mini converted to block
Your system handled 1433 units before dropping below 5 fps
Your system handled 512 units before dropping below 5 fps
Your system handled 98 units before dropping below 5 fps
CPU_04 ExtractRendermesh took :0.06 sec
GPU_10 Test took :0.19 sec @ 526.3 fps.
GPU_11 Test took :0.09 sec @ 1111.1 fps.
CPU_05 Joining meshes took :0.02 sec
MiniMesh converted to block
GPU_12 Test took :0.08 sec @ 1250.0 fps.
Same thing here @Holo :
Starting Holomark2
Rhino's language is English
1,  C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HoloMark2_Mini_black.3dm
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_Wire.ini
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_Shaded.ini
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_Render.ini
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_Illustration.ini
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\HM2_V6_RenderSpeed.ini
All is ok
Command
Command
Command
Command
Command
Command
Command
Command
Command
GPU_01 Cube 4 tests took :11.11 sec @ 1111.1 fps.
Command
Command
Command
Contour: 2.38703 s
CPU_01 Booleans and Contours took :3.75 sec
CPU_02 UDT Shape took :9.57 sec
Creating meshes... Press Esc to cancel
GPU_02 Test took :0.94 sec @ 106.4 fps.
Command
Command
Command
Time to regen viewport 10 times = 0.01 seconds. (666.67 FPS)
Command: -_Import
Name of the file to import ( Browse ): "C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\\HoloMark2_Mini_black.3dm"
Import scaling: Keep <ModelSize> ( DimensionNumbers ): _Enter
Read 1 annotation style and 32 annotation objects that reference 1 font that is not installed on this device.
Annotation style referencing a missing font:
	Century Gothic / Century Gothic Normal
Missing font:
Successfully read file "C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\\HoloMark2_Mini_black.3dm"
Command: _Enter
Command
CPU_03 Meshing Rhino took :2.1 sec
GPU_03 Test took :0.08 sec @ 1250.0 fps.
GPU_04 Test took :0.09 sec @ 1111.1 fps.
GPU_05 Test took :0.38 sec @ 263.2 fps.
GPU_06 Test took :0.49 sec @ 204.1 fps.
Your system handled 1195 units before dropping below 5 fps
Your system handled 395 units before dropping below 5 fps
Your system handled 114 units before dropping below 5 fps
GPU_10 Test took :0.2 sec @ 500.0 fps.
GPU_12 Test took :0.09 sec @ 1111.1 fps.
GPU_13 Test took :0.06 sec @ 1666.7 fps.
Rhino 7 SR21 2022-7-27 (Rhino 7, 7.21.22208.13001, Git hash:master @ c31aea87137a5d0de449338a7ef6856f49dd4797)
License type: Commercial, build 2022-07-27
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
  Primary display and OpenGL: NVIDIA GeForce RTX 3090 (NVidia) Memory: 24GB, Driver date: 7-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.93
OpenGL Settings
  Safe mode: Off
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 4x
  Render version: 4.6
  Driver Date: 7-21-2022
  Driver Version: 31.0.15.1693
  Total Video Memory: 24 GB
  C:\Users\EricM\Downloads\elefront422\elefront421\ElefrontProperties.rhp	"ElefrontProperties"	1.0.0.0
  C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\Holomark2_R6.rhp	"Holomark2_R6"	1.0.0.0
  C:\Program Files\Rhino 7\Plug-ins\symvol.rhp	"Symvol"
  C:\Program Files\Rhino 7\Plug-ins\Commands.rhp	"Commands"	7.21.22208.13001
  C:\Program Files\Rhino 7\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 7\Plug-ins\RPC.rhp	"RPC"
  C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp	"Rhino Bonus Tools"
  C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp	"AnimationTools"
  C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	7.21.22208.13001
  C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp	"Legacy Rhino Render"
  C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	7.21.22208.13001
  C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp	"Renderer Development Kit UI"
  C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 7\Plug-ins\MeshCommands.rhp	"MeshCommands"	7.21.22208.13001
  C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp	"IronPython"	7.21.22208.13001
  C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	7.21.22208.13001
  C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	7.21.22208.13001
  C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 7\Plug-ins\BlockEdit.rhp	"BlockEdit"	7.21.22208.13001
  C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 7\Plug-ins\Calc.rhp	"Calc"
Thanks, I’ll sit down and take a look when I have some time to dig deeply into this. Right now all I have time for is some mental relaxation when modelling a SubD car.
Hopefully I can finalize HM3 soon too, so you don’t have to use the old HM2 test.
