I am trying to hollow a dental model with fixture (needed for trim machine) as one entity by RHINO , I am not familiar with Rhino … Any one could help … i have tried Boolean function but no effectTM-1Lower.stl (10.0 MB) Y-R2138Lower7-h.stl (3.9 MB)
what is a trim machine? and how do you intend the hollowing and for what matter, if it is going to be 3d printed i believe the slicer adjustment would take care of that.
i need to make the 2 Stls similar ( hollow as one entity) like attached photo , it is not done during slicing
if there is another tool or software to get same result please advice
i assume you could use MeshBooleanUnion to create one single mesh. for the hollowing out steps i am afraid you would have to explain a bit more what exactly your intention is.
if you take a look at the model with fixture with name Y-R you will find that the fixture reserves behind Resin during printing and make solid part and sometimes it is really hard to crop from model itself
so i need to delete the intersection between the model and the fixture like STL name TM
i hope this is more clear for you
no photo attached. right now i am struggling to understand what you need.
is that what you need? if so you can use MeshBooleanDifference that will cut the orange part into the blue.
i did already but the orange part is not moved and the result is unexpected
if you are familiar with Rhino , could you try it please
i have no way of saying what is going on if you dont post a current rhino file
