I prefer a minimal UI, and would like to remove the viewport tabs shown in the picture below. Is this possible?
I guess it is not possible for now, but could this be added as an option?
i never ever ever used this tab, its basically taking space away for nothing. i really would also love useless clutter like this to be optional. and if one makes it optional then make the buttons be transparent, i mean let the text float in the viewport that it distracts less.
One can turn the tabs off in Windows Rhino, so I assume that it will be fixed sometime on the Mac side. I never use them except in certain files with lots of layouts, as there is a tab for each layout.
Hei Håvard -
Thanks, I’ve added this to the list → RH-78567 UI Appearance: Option to hide viewport tabs
Dear McNeel, please implement this! On a Macbook Pro 16”, at the default 1728×1117 resolution, that tab bar takes up 52px (real, not scaled) of vertical space while never being used at all.
Hi Visco -
Thank you for your feedback. I’ve added your post to the ticket.
Hi
Any chances to get this little feature in 9?
Agree, there should be option to hide it
You can move that to right Side vertically if you right click to that
