Help with Vector Field & Curves on Grasshopper
I’ve been trying to create some parametric art, inspired by Herschel Shapiro. Specifically, I’m trying to model something similar to his piece “Jagged Loop”, as seen here.
I’ve linked two photos to my work that I’ve currently done below. I know that Herschel uses vector fields in Grasshopper to achieve the effect shown in his artwork. However, what I am unable to figure out is how exactly each of the spikes follows a curve instead of a straight vector. This is more clearly seen in his Wisp piece [here] (Wisp). If anyone could provide some guidance or a GH file on how to make each spike follow a curve instead of a straight vector, that would be much appreciated!
Hello
you can use Flow with a nice Bezier Span
