Hi all,
I am asking for some help using tri/hexremesh. as i am still on rhino 6, i can´t use the command(s). could someone please try to remesh the meshes in the attached file?
i need triangular (delaunay) meshes and hexagonal ones.
important: the edge lenghts at the naked boundaries should stay untouched.
i don´t know which options are there for the commands, but it would be interesting to create larger triangles and hexagonal faces the farther away the faces are from the borders. if thats not possible, equally sized faces would be fine, too.
thanks in advance for any help
22_01_04.3dm (1.1 MB)
