Using TriRemesh with untidy mesh
Hello! I would like to use a re-meshing tool to clean untidy meshes. TriRemesh looks pretty good to me, but with the meshes that I would like to use, it seems to not work.
Here is my mesh:
test.3dm (363.5 KB)
And this is how it looks like:
How can I let it work? Or are there any better components for meshes like that?
:melting_face:
Unfortunately with meshes, the garbage in, garbage out concept counts. You can remesh it, but problems like non-manfold edges, self-intersecting faces, non-consistent face windings, etc. certainly will persist. After putting lipstick on a pig, it’s still a pig.
Hey! This makes sense, thank you! I found out that the ReduceMesh function from Rhino is pretty powerful. I think I can work with that.
Greeeetings
lips-cute
Depending on the geometry, you can sometimes take a bad mesh and wrap a good mesh onto it like this Introducing TriRemesh - high quality triangular and hexagonal remeshing and shrink wrapping - #9 by DanielPiker
Looks interesting! I’ll take a look at it. Many thanks!
