Help with Modeling
Hey, I am trying to model this stool made of bamboo. Does anyone know what the fastest or best practices of steps would be to model this?
Top and bottom circle. Divide both circles. Shift the points of one circle. Connect the points with lines. Pipe the lines.
Edit: Oops not grasshopper.
Still - just draw a line from one circle to another and pattern it and pipe it.
Probably Circle>Divide Curve>Extrude Points>Twist>Pipe
check also Hyperboloid
as @ftzuk wrote
workflow / commands from left to right
(1)
_circle
_copy vertical
_line
(2)
_pointsOn
_rotate with centerSnap
(3)
_pipe
(4)
_arrayPolar
hope this helps.
try it.
post a 3dm file with your result if you have further questions.
kind regards -tom
alternatively for a better preview, create one line polar array it, turn points on and rotate the upper points with gumball, optionally turn on history then pipe.
