Help with layout blocks
Can you have blocks in excel that have text that is fed from an excel file?
I have two types of layout templates and they have some duplicate information and I’d like to have rhino pull from an excel file so I don’t have to keep exploding blocks, diting them and then reblocking.
If I can’t export from excel, whats the best thing to search to look for the best way to create these information tables as blocks or other objects?
use excel then load data in grasshopper. use elefront to insert blocks in gh as a template. inside template have points which will serve as insertion points for texts etc and have it named ccording to position of data in excel. copy blocks according to position code defined in excel. explide blocks in gh and use insertion points to insert data
