Help with joints for voronoi structure
ROTULA 01.gh (16.2 KB)
representacion.3dm (2.7 MB)
Hello, what I need to do is based in the drawing below, I have the structure base in Rhino and grasshopper but I don’t know how to work with the intersections to do the voronoi structure with mobility. I need to create a joint with components that connect the joint to the Voronoi structure and allow mobility within the structure.
maybee this?
230824_GetFaceLoops-ver 2.gh (12.6 KB)
@Rh-3d-p
Screenshot 2023-10-17 081208
Looks like you have some of them inside the cells? :thinking:
Hello, do you know also hoy to change the shape of the Moroni so it will look more like polygons?
how did you obtain that result?
Yes if you want ngon or polygon unit the algorithm must be change
@Luana_Issaurat
yes!
ROTULA 02New.gh (30.3 KB)
also we can use Delaunay Edges
ROTULA 03New.gh (26.6 KB)
