Hi i cant seem to make this flow along surface happen. I have used this command before with good luck but i cant seem to figure out what i’m doing wrong. My intention is to make this bunny a relief on a bracelett. Therefore i want to flow it so i can put it on the surface of the bracelet. no matter what i do it gets morphed somehow. I hope someone can help. Thank you
UnrollSrfUV the bracelet.
Use the unrolled surface as the Base surface in FlowAlongSrf.
Thank you ! just curious and only if you have time but what exactly does it mean to unroll it? just then i might remeber it better for next time !
I updated my post to suggest using UnrollSrfUV instead of UnrollSrf.
When a surface is “unrolled” it is flattened. Shapes such as cylinders and cones can be unrolled with the surface area, lengths of edges, etc unchanged. Such shapes are called developable.
Looking at the wireframe of the bracelet, it is not a cylinder. I think Squish would be required instead of unroll.
Hey!
would you please attach the file?
