I am working on a model using grasshopper and it was working fine until yesterday and I was able to even bake the geometry and modify it but for some reason all of a sudden, the baking feature is not working, I tried it multiple times and still the model in rhino is in the volume form instead of a mesh and convert it to a subd. I was able to do them for quiet some time so far but for some reason it is not working now. I am able to perform all other commands in grasshopper except this. I also tried redoing the whole script but still the same issue persists.
Hey Laurent!
Thank you for the reply.
I added the volume to mesh node and tried baking.
It came up with a pop-up window saying that it has invalid objects to bake and when I try to bake on the custom preview node, the bake feature is inactive.
This did not happen the last time I baked the geometry using the same grasshopper file.
Can you please guide me with this issue?
Thank you
It is quite common to have invalid mesh. You can cure them in rhino.
I made a little tool in nautilus-plugin thats heals the mesh.
Not on my pc now but it is something like degenerate faces. A face with 2 same points.
