Hello!
I make a mesh (topography) from curves (contour lines) with grasshopper, but i cannot bake it. The pop-up appears and everthing looks normal, but the terrain just doesn’t bake. I guess it’s because are so many curves.
(I use Rhino6 in PC)
Thanks for your comments, sorry for the bad english.
Topography.gh (3.3 MB)
Does it say “Invalid Mesh” somewhere (if you hover over the related outputs or parameters)?
if so, the mesh needs to be fixed. Rhino6 is “sensitive” about (in)valid meshes.
// Rolf
I used some tools made by @laurent_delrieu to cull degenerate faces which seems to have fixed your invalidity problem.
Topography_fix_dz.gh (3.3 MB)
Thanks a lot! you solved the problem
