I have a microscribe 3dx bought very cheap, wondering which version of Rhino3D supports it? Will either version 5 or 6 support it? I have machines that run on Win 10, 7, Vista, XP
Thanks
Vic
Thanks
Vic
Hi! I also have a Microscribe 3DX that I try to use with Rhino 6 on Windows 10, but I can’t get it to work. Did you solve the problem?
Regards / Jimmy
Mine worked, I had an old dell 920 which had a serial connector built in the motherboard. No driver required for win10. Perhaps try a USB to rs232 converter if you don’t have a serial but this is a guess.
Good luck
