Hi everybody,
I have been a long time Rhino user, and this forum has helped me more than once as a spectator. So thank you all for that. But now I have no luck in finding a similar problem on the forum, hence my first post here (yay).
So I am hoping that one of you guys can help me out.
The problem description is as follows:
- When I create a material for a piece of geometry and add an image ( for example .jpg) as a diffuse color texture it shows fine, until I save the file, close it and open it again. Then the texture doesn’t show in rendered mode. Instead it often shows some sort of standard studio environment image. When I replace the texture with a completely different image file, or change the file name, it shows fine again. Until I save the file, close it and open it again.
As I said: sometimes instead of the diffuse texture image, Rhino shows some sort of studio environment image as diffuse image. Like this:
And sometimes Rhino swaps out diffuse texture images between different materials, like this:
This is driving me nuts. Hopefully, somebody here has a solution.
- I am having this problem since Rhino 7.
- It does not always happen.
- My RHINO system info can be found at the bottom of my post.
- My Video hardware and driver information is as follows:
Radeon RX 590 Series
OpenGL version: 4.6.13596 Compatibility Profile Context 20.10.35.02 27.20.1034.6
Render version: 4.6
Shading Language: 4.60
Driver Date: 8-21-2020
Driver Version: 27.20.1034.6
Z-Buffer depth: 24bits
Stencil depth: 8bits
Total Video Memory: 8 GB
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: Radeon RX 590 Series (AMD) Memory: 8GB, Driver date: 8-21-2020 (M-D-Y). OpenGL Ver: 4.6.13596 Compatibility Profile Context 20.10.35.02 27.20.1034.6
> Accelerated graphics device with 8 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Z-Buffer depth: 24 bits
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Iris (1cd9c8f5-c901-426c-8e80-d6a2e2b18bba)\1.0.7284.18297\Iris.WinR6.rhp “Iris” 1.0.0.0
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.0.0.0\KeyShot9RhinoPlugin\Rhino 5.0\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.8.21196.5001
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.8.21196.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.8.21196.5001
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\SectionTools (fbdb1d7f-8cfb-42c1-9858-87cb6315932c)\2019.7.29.584\SectionTools.rhp “SectionTools”
