Help in grasshopper
Hii everyone, I want the red lines to stop when they intersect with the green lines. Does someone know how to do it? I can´t figure it out by myself.
This is what I got
Help1.gh (12.1 KB)
Dear wwwbss.122. (just checked :wink: ) this is your second topic. Both with the title: “Help in grasshopper”. In this forum we all need more (or less, or no) help, or are busy giving it.
May I invite you to use more meaningfull titles: Mabye: “How to stop lines when they intersect with other lines”
I hope I understood your question well:
Shatter is a good solution, but gives in your example many thousands of lines. Not easy to manage.
So I made a solid brep from the “green lines”
and split curve with brep then gives your lines cut in 0, 1 or 2 pieces.
Select the ones you want to keep (or cull what you want to loose)
Regards, Eef
How to stop lines when they intersect with other lines EW.gh (26.6 KB)
quick and dirty method:
Dear Jeff, how did you solve that all those lines are not in 1 plane. To not miss lines I made the brep
I didn’t even notice they’re not all on the same plane until now.. (and I now see a few of the lines were missed using this method)… as I said, quick&dirty :wink:
@jeff_hammond I think if you feed in the XY Plane, it would work fine.
