How to tell Grasshopper, if there is intersections
I have two questions,
  1. I want to tell grasshopper if there is an intersection between line 1 and line 2, do this.
  2. But, for sure there is one intersection in the middle of line 2 because I made line 2 from line 1( dividing line 1 into several parts, then made line 2 perpendicular to line 1). However, I want to know if there is an intersection other than the middle ones.
    how can I do it?
    You can See the intersections that I want in Blue Crosses.
    22 Test_inter section.gh (19.1 KB)
and also there some intersections on the down lines. there are two rows intersections
Internalize the geometry
Test_inter section.gh (21.1 KB)
maybe this version is better
there is one definition on the right side of the file which I deactivated the. They do not seem to be a solution, but take a look at it, it may help you
This?
Test_inter section.gh (22.7 KB)
no, Actually I do not want the middle ones, I want these ones.
Dude I really strugle to understand. What do you mean first of all by line 1 and line 2?
And what do you mean by “the middle ones”?
ok de
I want these ones.
and by middle ones I mean these intersections. middle one that red lines these intersections
I found this from the deactivated commands in the right side of the GH file. but it is not correct, because I have to find all the intersecion, and cull the ones which are in the middle. In this file I tried to deceive grasshopper :joy:
Test_inter section.gh (22.2 KB)
that’s awesome, Thank you, can you tell me what Invert do? I just want to learn.
Turns True to False and vice versa.
Thank you so much David
No worries mate! The whole trick when you want to Cull something is to think of propper criteria how to do it.
Just one more question, can you tell me if there is a component telling me ( if there is intersection: true, if not: false)
You can make one…
True_False.gh (7.7 KB)
This is just an idea. You have to make it so it solves it according to whatever logic you have. This is just a simple example. When you start working with trees and branches then it becomes a bit more complicated.
After you finish with the logic, just create a cluster, put a name to it and whatever logo you want and create an user object so you can always use it.
perfect thanks
sorry for bothering you again, I am stuck in this issue.
You showed me how to find intersections. Now I have another problem. Before the problem with intersection, I asked grasshopper for checking if the end of the lines in X zone, if it is inside X zone, offset the Intervals and make a surface as you can see in the picture.
You can find the definition inside the GH file.
Now I want to tell grasshoppe that before considering the end of the line if it is inside X zone or not, check if there is intersection between Line A( Blue) and lines B(orange) , if yes, offset the intervals and make surface how we made surface in X zones( by intervals).
temp 2.gh (41.4 KB)
