Hello! I need some help, I have lines going straight down to the x-y plane and I need all the lines that intersect a brep to stop there and the other ones to keep how they are. Is this possible? Thank you in advance.
try the function ‘BCX’ (brep curve intersection), output are intersection points. you could choose to redraw your intersected lines from starting point to intersection point.
Thank you, i didn’t think of that. I’ll try this out.
This worked perfectly using by breps in the obstacles instead of the starting surfaces, thank you very much.
