I am trying to make the pattern sketched in the top image, ive made one unit of the image pattern in grasshopper already with the file below, how to I pattern it to make the mirror functions and everything work to make it look like the sketched image? I tried using a grid to pattern it but I can get it, I want a 8x8 grid of the pattern
Three? I see a corner piece, often mirrored to form a âTâ, and a white âbarâ. (Is there a âbarâ missing in your colored image or is that deliberate?)
@lars.renklint is doing a fine job and I donât mean to interrupt hereâŚ
The following uses his method in the purple group but the input comes from the white group, consisting of one âSrf Cornerâ and one âSrf Barâ. They are surfaces but could just as well be extruded solids. How they are made is left unspecified. Also, ArrPolar requires a âPt 1â point to be specified and the two Mirror components require a âPt 2â point.
Thanks Joseph, thats fantastic, the orange are hinges to be one material, the white doesnât require a material as there is no print there and the grey tiles in between need to also be extruded to be a rigid tile print body. I see I can now control the extrusion depth in the yellow rectangle but how do I also add the extrusion of the grey tiles inbetween the hinges? really appreciate your help, it is very motivating to keep learning!
Gulp. This got messy quick because I didnât consider the middle âtileâ part from the beginning. In fact, this was originally a quick hack just to illustrate a way forward. Due credit still goes to @lars.renklint for implementing the tile/mirror/array idea (purple group).
I donât know what you mean by âhingesâ but I added a gray group to âcut outâ the middle âtileâ portion as a surface, optionally extrude it with its own âtile thicknessâ slider, then add it as a third branch to the data tree.
Itâs a long way from where you started. I hope you can understand and âown itâ, to modify it as necessary. After all, this forum is about learning Grasshopper, not just doing someoneâs work for them.
