I am taking a tech class this year that is using Rhino7. I need to make the object a solid (closed poly surfaces.) Currently, I have 21 naked edges. Can someone please fix this issue for me? I am a beginner at Rhino and do not understand too much about it.
Select the resulting surface and run the _ExtrudeSrf command with Solid option and extrude to your desired thickness (also select the DeleteInput option if you don’t want to keep the input surface):
