I’ve created a topographical surface in rhino, and I want to produce a .jpg black/white height map from this.
Is there a way to do this through either rhino or a somewhat simple grasshopper definition?
Thanks,
C
Thanks,
C
Chris,
Is screen resolution is enough, you may try ShowZBuffer command in Top view.
(AFAIK hi-res viewscaptures will not work well with that method).
hth,
Jarek
Rendering a topview and in the Render window press the button to show zdepth. Than save a height image.
I’m on my phone so let me know if this does not make any sense. I’ll elaborate tomorrow when on my laptop again.
-Willem
@Margaret
I tried the online help to find info on the render window and it’s layout but to no avail. At least not via linkage in the topic about rendering. Thanks Willem
Thanks!
I got it to work with the Rhino Renderer>Show Distance Channel
