Heavy prints with transparent hatches (And a FIX!)
Hi McNeel,
I’m printing a drawing with a lot of transparent hatches on top of a raster image.
7 pages turn into a 120Mb file.
I asked an LLM why it was so heavy and the reply below reveals that theres an additional transparency options object added to each triangle of my hatches(!)
Found it, and it's gloriously stupid. Your 124 MB PDF contains 961,334 objects — 961,242 of which are graphics-state
  dictionaries. There are exactly 4 unique ones.
  The byte budget
  │                           What                           │  Size   │ Share │
  │ /ExtGState objects (961,242 of them, 71 bytes each)      │ 65.9 MB │ 53%   │
  │ /Page dicts — almost entirely the name→ref map for those │ 21.9 MB │ 18%   │
  │ xref table (961,335 rows × 20 bytes)                     │ 19.2 MB │ 15%   │
  │ Actual page content streams (compressed)                 │ 15.5 MB │ 12%   │
  │ The 16 JPEGs (1081×1599, legends/logos)                  │ 2.1 MB  │ 2%    │
  960,772 of those objects are byte-for-byte identical:
  <</Type /ExtGState/CA 0.90196078 /ca 0.90196078 >>
  0.90196078 = 230/255, i.e. an alpha of 230 — a 10 %-transparent fill.
  The mechanism
  The details print the sunlight-hours mesh as vector, so Rhino explodes it into ~113,000 individually filled triangles
  per page. Each one looks like this:
  q  /GSaZfsU56516 gs  /DeviceRGB cs  0.784 0.313 0.274 sc
     293.4 328.4 m ... l ... h f
  Q
  Because the fill is semi-transparent, Rhino's PDF writer (Xfinium — its fingerprints are all over the catalog) emits a
  brand-new ExtGState object for every single triangle instead of reusing one. So each triangle costs an object + a
  resource-map entry + an xref row on top of its actual geometry. ~86 MB of the file is one repeated "90 % opaque"
  instruction, written out a million times.
The LLM also ‘merged’ those entries in my pdf cutting file size to 15Mb (-90%) with same print output. I’m suggesting that rhino does that automatically.
Which LLM model is so condescending?
my agents.md forces it to speak like jimmy carr. No kidding. I don’t want the flatter.
I don’t like the ‘I love your idea’ style either. To say it’s ‘gloriously stupid’ rather than, “inefficient”, is simply imprecise and subjective, and on a par with ‘I love your idea’. In my opinion.
@dale not sure if this should be reported as bug or feature
It would help to have the 3dm that produces this so we can reproduce the issue
Hi @stevebaer i got to investigate it a bit some more.
It wasnt our baked transparent hatches;
it was a custom conduit doing a falsecolormesh. Our fix was to return on that conduit if viewport is on a detail. However the weird thing is that this bug happens even if none of the conduit previewed items made it to the PDF.. So even if i didnt have any details at all on my layout, it still gets heavy from conduit stuff.
F07_Plan_noFalseColorMesh.pdf (43.7 KB)
F07_Plan.pdf (14.4 MB)
my fix in my local code, can’t disclose much more.
