I’m struggling to persuade the hatching tool to solid fill and let me keep the fill after having tantalizingly previewed it for me. I’m sure I’m missing something obvious, but please, tell me!
Oddly it does display hatch in the layout.
thanks in advance,
Giles
machine stats are:
Processor Intel(R) Core™ i7-7700HQ CPU @ 2.80GHz 2.80 GHz
Installed RAM 32.0 GB (31.9 GB usable)
Device ID AB7336A2-F193-496C-8BE1-7E00F03D6DE1
Product ID 00325-96157-89397-AAOEM
System type 64-bit operating system, x64-based processor
Can you run the command SystemInfo in Rhino and copy/paste the results here? Note also, that despite the image above, you do not have the latest version, we are at SR 11…
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 10-14-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 Ti (NVidia) Memory: 4GB, Driver date: 7-5-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 451.67
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-5-2020
Driver Version: 27.21.14.5167
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
If, in a new file from a factory-default template, you make a rectangle and use that to create a solid fill, does that stick? If it does, could you post a file where it doesn’t?
Thanks.
How are you trying to apply a hatch to these curves?
There are 9 closed curves in that file - 7 of those create the “LK160” name. The two others are very short curves that appear to be garbage.
The other 82 curves are open. I don’t know what your intentions here are. You might want to run the CurveBoolean command on all curves and click outside the boat. That will generate an outline that will hatch.
Thanks, I’ll try that command. I didn;t really need closed curves as I’m just in 2d, but i’ll see if that sorts the hatching. It’s just the black hatching in the first image I’m trying to acheive.
