Hatch wish: radial fill for circles at 100%?!
Hi @stevebaer,
can you optimize the hatch radial fill for circle curves.
I would like to have the right color at 100% at the radius point.
The maximum calculation seams to be based on the control polygon, and not the maximum distance from the center.
I hope my picture explains it better:
Thanks
Michael
www.flexiCAD.com
Assigned to Rhino category.
Hi Michael - I see that… I don’t know if that could somehow to be ‘special-cased’ for circles - my guess is it’s using the bounding box max and not the control polygon-
they happen to coincide in this case.
RH-70728 Hatch: smarter default size for radial hatches
Hi Pascal,
you are right, the bounding box is used.
A maximum distance calculation from center to vertices would be much nicer in any case, also with your ellipse case, I think.
Thanks
Michael
