Fill areas with color
Hi, does anybody know how to fill areas of a 2D sketch with a color?
Hi - you can use the Hatch command to fill closed curves.
See the help file here: https://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/hatch.htm
HTH,
wim
Super helpful!!! Thanks a lot!!!
Wim
I have the same problem as Marco. I went to the tutorial that you suggested (thanks) and it led me to Hatch. When I went to Hatch I was able to fill an area in my design with solid black, but I could not find how to change the color. Can yoiu help please?
Thanks in advance.
Dick
Hi Dick - hatches are like any other object - they have a Display Color set in Properties - you can make changes there.
Pascal
Many thanks! I still need some practice to become facile in coloring things, but thanks to you I now know the basics of doing so.
Cheers
Dick
