HI all,
is there a workaround to get curves that sometimes are overlapping and make a hatch selecting the regions in a smooth way? A solution to the limitation would be so usefull, since resolving it would put Rhino as a 2d editor on a different level!
yes exactly, with self intersecting curves, or curves that have overlapping points, it makes error. A classic example is at corners when the corner of the facade meets the corner of a column. What i have to do is move the point, and obviously is not so nice
HI @pascal,
this is the exaclt the portion of the drawing that is not work, withouth this piece it works smooth.
there were a series of block, then exploded. Looks like a bug to me, but i am not sure, i would be more than happy to understand if there is a drawing error.
Right exactly!! I cannot get the menu from the hatch command, how can i do that? I have just the option from the command prompt. Can it be also a rhino version problem?
HI Thanks again for the reply, actually i looked a bit more in depth, and it is not that the area i am trying to hatch the one you did, but the one i highlighted in the sketch below.
can you try to create a region for this ? does it work? i am still not able to produce a hatch for the highlighted region
Yeah… that counts as a self-intersecting set of curves - hatch will not make that - your material would have zero thickness there so that is probably an OK decision by Hatch… I do not know if that is fixable - PlanarSrf also does not like that.
