Odd occurrence when I print more than one Layout while using hatching…
If I print just one Layout (regardless if it is Layout_1, Layout_2, or so on…) the hatching behaves normal and stays/prints within the defined (in model space) part boundary. But, if I print more than one Layout (in the same batch) the hatching on the prints for Layout_ 2, 3, and so on (but NOT Layout_1) print outside of the part boundary with triangular shapes even though the hatching features are just a copy (in model space) of the original one. Has anyone seen this and perhaps can share a work-around or should I “fish and stop cutting bait.”
I always print Layouts in Wireframe mode/Raster Output Type. In addition the hatch bounding features are quite small (but closed curves 0.05sq in) in size and the hatch is solid. Edit: I have played around with the hatch scaling but no improvement.
Hi Steve - can you please update your ati driver to the latest available for your card - from the ati website, don’t believe what Windows may tell you about it being up to date. Then try the print again…
