Hatch not following boundary
Hi there
I’ve run into an issue when making a very large hatch:
This is part of a hatch that is 1150000mm long and between 600 and 2200mm high, but get’s printed to multiple pages in 1:1000. Does this issue have anything to do with my tolerance settings? If I make the hatch on a smaller section of the “wall” then it fills in perfectly.
Hello - solid hatches use a mesh and the accuracy will (I believe) follow the settings in DocumentProperties > Mesh page.
Hi Pascal,
I did some test for this but I did not see a change in hatching with different mesh settings.
Maybe I’m wrong but just wanted to let you know
-Willem
An existing Hatch will not update on it’s own.
The test would involve deleting the existing Hatch, and re-hatching it again with a closer fitting mesh setting.
Hi John,
That’s what I did and found no difference in the old and new hatch.
It might be I did not test under the right conditions so did not find differences. Can you confirm that you indeed see difference when testing as you proposed?
-Willem
Yeah… I do not see any sign that is does as I claimed… I’ll see what I can find out.
RH-67216 Hatch: Allow custom mesh settings
