Halftone like point pattern, geometrical problem
Hello
here is the definition, it is not very easy to use this circle packing as it is interactive. There are many links
https://www.grasshopper3d.com/m/discussion?id=2985220%3ATopic%3A1834244
Two first thing is to set a range of radius (the same for you) and a number of points.
The idea is not to put too big circle/sphere at the begining there must be room for the growth so the multiplier MUST be at a low level 0.1 0.2 … Then increase the slider. Don’t forget to set to true the toggle.
You will see circles growing. When you are happy set toggle to false
I also put a Lloyd relaxation. Here also you have to try. It could be optimized, not moving exterior points for example …
There are many parameters. To see Lloyd look here, it is a bit like you problem, but not following curves.
I put a mesh sphere in order to have black dots. I have some problems with Dots
point_pattern_GH_LD.gh (468.7 KB)
