Hi there,
I have a set of curves(green ones), and points along those curves that I would like to divide them with. What I would like to do is similar to what dashpattern does, I would be able to use divided curve pieces, but it doesn’t work because I believe it is starting to split the curve with a set of dimensions, starting from the beginning of the curve, so the divided pieces don’t align with the perpendicular curves(red ones), that’s the important part.
These curves and points are coming from a more complex file, so I’ve saved the necessary parts only to make your lives easier. Also, as you can tell, instead of using the points, the perpendicular curves can be used to divide the green curves as well.
Test.gh (34.8 KB)
