Quite often I wish there was a Scale2D available via Gumball (unless I am missing something this is not currently possible, right?). In that case from UI standpoint, how about adding a 4th scale-like handle at the corner of the transform plane? (see below)
Another request or idea: ability to make multiple copies when transforming with Gumball or dragging. Now when we tap Alt, a copy can be made but not until the transform or drag is complete. What would be handy is to be able to make copies “as we go”, transforming the object(s), with a tap of a key. Considering the current key assignments that are “taken” already, how about Backspace?
So basically the Backspace key press would make a copy of the selected objects on the spot, while not exiting the drag or Gumball-transform mode.
Throwing it out there, hope it makes sense and can be considered : )
Great! I had no idea, but it is right there in the Help file (but poorly discoverable, I guess - the handle would make it obvious without extra key press).
How about the 2nd part (copying while dragging) - possible already??
Thanks, but that’s not what I am after. I don’t want a single copy at the end of drag/gumball transform. I need a copy every time I press a key, while still dragging/moving/scaling/rotating. A snapshot anytime I press a key. Is that currently possible ?
