Gumball settings for arc arrow tips?
UNDERNEATH ~ Settings, Modeling Aids; Gumball ~ there is a wealth of fine-tuning available for the Gumball.
Including, arrow Tip length and Tip width
Including, Arc thickness.
The direction of the (small) default arrow tips are not always easy to distinguish against a busy background. However, there appears to be no ability to vary the size of the arc arrows.
Would it not be to advantage if they could be made bigger?
With the x, y and z arrow-tips able to be fully adjusted, would it not be possible also to make the rotational arrow tips adjustable?
Thank you for your feedback. This does appear bo be an area for improvement. While the Tip width option controls width of the Arc Arrow, the Tip length option does not affect its length. I will log this issue to our development engineers later. This issue has been logged to our deveolpment enginners.
RH-89749 Gumball: The length of the Arc tips cannot be adjusted
