I use the gumball all the time to move things in X,Y,X, and rotate in X,Y,Z however… so often I do not get the little square boxes to appear to let me scale in X,Y and Z. I can only scale in 1 dimension… Am I missing something?
In the attached image you can see I can only scale in two dimension (Really just 1 because my surface is flat). I can only scale in width. I cannot scale in height…
Yeah, but in the image the red scale grip is present, which is the one in the plane of the curve (note the presence of the cut tool) and the blue scale box is absent, which looks wrong to me.
But the squares are oriented in the wrong direction. My object definitely has height and width. It’s a little hard to see in the image. It’s flat in depth which is what my gumball is giving me a scale dimension for.
Link to Video. Showing a different curve but same issue.
