May I suggest that the gumball pivot move (custom, not centered) snaps around the pivot and not the mouse (gizmo) ?
Or… What is the way to move the pivot using snaps ? (faster than relocate)
Regards
Regards
Hi Lahos - hold Ctrl (cmd on Mac), select the gumball origin and drag to the desired location using the appropriate snaps - does that do what you need?
The sequence was not obvious.
Press control, click and hold mouse button and release control.
If you don’t release control, the only way to move pivot is to click the 4 squares gizmo…
Once you know it, it’s fine !
Thanks !
