In 3DS Max I can select an object then type coordinates in the move transform box and the object will move with the pivot centered on those coordinates. Is there a way to do a similar thing in Rhino? I have often needed to center an object at the origin and can’t seem to find an easy way to do this.
If I understand you correctly you can grab your object, then click and drag the gumball at the “point” where the arrows meet up. While you are still dragging you can type an absolute coordinate and it will move the object to that location.
