Gumball: 'Align to Object' - Gumball does not align properly
What to do if the gumball doesn’t align with the object. Thank you
Only certain types of objects are valid to “align to object” - those for which a logical alignment direction can be found. This includes things like lines, planar curves and surfaces, all of which have a specific direction vector as an inherent object characteristic. Polysurfaces are not included as they can be arbitrary.
If the Gumballl has been moved, you can try ‘ResetGumball’. For a polysurface as there is no “align to object” possible, this will end up being the same as World or CPLane alignment.
`Thanks a lot MItch for clarifying! @Helvetosaur
