Extrusion confusion
Why when extruding curves into surfaces with the gumball in rhino 8 do i get open SubD surfaces instead of open polysurfaces.
the curves are Planar.
If you create the curve with the SubDFriendly option set to yes the gumball will extrude it as a SubD. Otherwise it will be extruded as a surface/polysurface.
Legend! thank you!
