Hello Forum,
I would like to change the gumball appearance settings using RhinoCommon under Rhino 6 as well as I would do manually using the tools/options/… menu. For example I would like to change the gumball default radius to 77.
I read the forum and found some code like this (with little understanding) and no, it doesn’t work. I guess it was for something else.
var baseGumball = new Rhino.UI.Gumball.GumballObject();
var displayConduit = new Rhino.UI.Gumball.GumballDisplayConduit();
var appearanceSettings = new Rhino.UI.Gumball.GumballAppearanceSettings();
appearanceSettings.Radius = 77;
displayConduit.SetBaseGumball(baseGumball, appearanceSettings);
displayConduit.Enabled = true;
Any idea?
Thanks. L
