I am new to grasshopper and I am trying to create lists of nodes and elements to group them before I bake the model into GSA.
My model consists of a concrete slab and piles therefore my plan is to group (list) these elements (slab, piles) and their relative nodes so that I will be able to load them seperately in Oasys GSA.
I tried to use the ggGSACreateList command but it doesn’t seem to work for me.
Nice to hear from you. Are you using GSA10? I just tested the attached gh script and got the resultant GWA that worked here. If you get different results, can you share so I can review?
It’s been a long time but using grasshopper had been postponed due to the project.
Indeed I am using GSA 10 and I have the same issue for the explicit section properties. Even though I create them in GH the elements are not created in GSA.
With regards to the lists: I even used straight your gh script and opened gsa but no lists were created.
