Grouping Hops Components in "Available functions"
Hi @AndyPayne and all,
When developing a Hops server with multiple components, organizing them into logical groups in the Grasshopper interface can be challenging.
Even when using the same category name, components often appear under separate tabs:
#Group hops function
CATEGORY = "Plots"
@hops.component("/group/function_0",
    name="___",
    nickname="___",
    description="___",
    category=CATEGORY,
@hops.component("/group/function_1",
    name="___",
    nickname="___",
    description="___",
    category=CATEGORY,
Despite using the same CATEGORY constant, these components appear as separate “Plots” tabs in HOPS “Available functions”.
None of these methods successfully grouped the components under common tabs:
  1. Using consistent category strings
  2. Using subcategory parameter
  3. Using forward slashes in category names (e.g., “Plots/function_1”)
Has anyone found a reliable way to group Hops components under a single tab in Grasshopper? Or is this a current limitation of the Hops/Grasshopper interface?
Related post : Organise hops-server components using flask Blueprints
Drop-down available functions · Issue #363 · mcneel/compute.rhino3d
